搜索 | 用户支持
详细了解
Why when I am in private browsing and I open a new tab does it go to regular firefox onstead of in-private browsing?
  • 2 个回答
  • 3 人有此问题
  • 1 次查看
  • 最后回复者为 cor-el
Just today when I open a new tab while in private browsing it opens up not in private browsing. Also my purple mask has disappeared from the in private browsing screen. What gives?
所有回复 (2)
Has this happened before?
Note that you won't see the purple mask when you start Firefox in permanent Private Browsing mode (Always use Private Browsing mode; Never Remember History).
You can use an extension to get Private Browsing mode support per tab.
Private Browsing mode tabs get a dashed underline You can toggle Private Browsing mode on/off via the right-click context menu of a tab
